theasus
Member level 3
I want to use IR led and photodiode in my project as a sensor. And for stable working I have to assure constant current for IR Led.How can i do this operation?Could you post a simple circuit and its usage?
theasus said:Could you propose more sensitive circuit ?
I think this is not a sensitive.And this one more sensitive but i couldn't calculate the compenent values(transistor,resistor..)
Could you help about this circuit?And also for this operation we can prefer fet to transistor.But as i said i didn't calculate the right value for one led driving.
vistapoint said:This is how you calculate:
The input+ has a voltage set by the zener diode=Vz. Input- = Input+ due to feedback. So Vsense=Vz. The current through the resistors=Vz/Rsense
This is a good current sink, better than other designs in this thread.
__________________________________________
Low-price resistors, capacitor, and LEDs: **broken link removed**
