D.A.(Tony)Stewart
Advanced Member level 7
- Joined
- Sep 26, 2007
- Messages
- 9,912
- Helped
- 1,856
- Reputation
- 3,713
- Reaction score
- 2,416
- Trophy points
- 1,413
- Location
- Richmond Hill, ON, Canada
- Activity points
- 63,305
This will draw 0 mA until you switch the load on.
I would use 3 identical circuits in parallel each feeding 1.066 Ohm with a fixed 0.75 Ohm power resistor.
or preferably 4 same ccts x 1A each with 1.250 Ohm power resistors.. Use TO-3 regulators if the pulses is repeated often otherwise TO220.
Regulation will be the same as the accuracy of the resistor. The internal reference voltage is very tight 1.25V. Heatsink all 3 terminal regulators and will draw 0 current unless load is connected. Total Cost $10 depending on source.
no PCB needed... use 0.1uF on input if long lines.. response time < 1mS.
