newbie_hs
Full Member level 2
- Joined
- Mar 4, 2023
- Messages
- 134
- Helped
- 1
- Reputation
- 2
- Reaction score
- 2
- Trophy points
- 18
- Activity points
- 1,068
I made a connector small board based on this document .In page no 21 you can see "4.5 Load Impedance variation".
You can see that (Figure 36) signal from Bode 100 channel 2 is coming to one end of the load board and the other end is connected to WPT coil.
My schematic is given below.
From Bode 100 signal is coming to BNC and I will select one load at time(either 1R,10R ,22R etc). and the Output of J1 is coming to WPT coil.
I made a mistake in the schematic,the J1's 1st PIN is ground and 2nd PIN is signal.But I connected 1st pin to Signal and 2nd PIN is ground.
The signal coming from Bode100 is an AC signal.My question is will this connection error has any impact or not.
