connector to 128*64 Character LCD Display
Mazytis
Newbie level 3
Newbie level 3
Hi everyone, my English speech is not very well, so I hope you understand me.
I bought graphic LCD display from ebay:
But I cant to find connector to them, maybe someone can help me?
Thankyou
1) you need to count the number of contacts.
2) And you need to measure the pitch. Typical values are 0.5mm, 1.0mm... => and 1.25mm and 1.27mm !!
Hint: measure the distance (center to center) from pin 1 to pin 11 and divide it by 10...
Hope this helps
Klaus
Poor information on EBAY is common.
wiring dwg shows 12 fpc contacts with only enough width for 0.5 mm pitch but does not show thickness with pullout substrate tab.
Perhaps std. Thickness.
So my description is
Connector, FPC , Receptacle, SMT 12x0.5mm
Pitch is 0.5mm.
farnell has about 30 differnt types of it...
one major thing to consider is that some connectors have the contacts on top and others on bottom.
I think all of them are SMD types. Maybe you find an adaper PCB.
Some are ZIF some are not.
Some have horizontal FPC entry some vertical
Good luck
Klaus
