T
treez
![Newbie level 1](/styles/images/ranks/alevel1.gif)
We have only 3 wires from which we must supply two Buck led drivers. If we use the MIC3205, then can we place the sense resistor at the bottom of the led string instead of the top? –(If so then we will indeed be able to use just 3 wires to supply the two led drivers).
MIC3205 datasheet:
MIC3205 datasheet:
