brightnight1
Newbie level 3
I'm making a design from a schematic that conditions a signal from a PIR circuit and goes to a microcontroller to run code when motion is sensed. At the end of the design before the signal goes to the microcontroller, there are two op amps that are used as a comparator, with both op amp outputs tied to a NAND gate.
The schematic says the NAND gate is optional. If I can build this using less components then I won't use the NAND gate. However, I don't know what to do with the outputs from the op amp. I assume I can't just tie them together and put them into the microcontroller? Any advice appreicated. Thanks in advance.
