venkates2218
Full Member level 6
Hai,
While grounding the PCB
Method 1:Created an PCB,mounting hole with PAD and conductive material is used to mount the PCB on machine.Whole body of the machine is connected to ground.continuity between the ground and earth is available while checking with multimeter.
Method 2:Created an PCB,mounting hole without PAD and earth is connected to single point.An "Ferrite Bead, 70 ohm, 3 A, 0.04 ohm, ± 25%" is connected in series with GND and EARTH pin.
Please suggest which one is best or any other method to connect the earth to PCB
