Connecting 6VDC relay with Arduino?
NishantSood
Junior Member level 3
California Love
I bought a bunch of Relays that i want to connect with Arduino UNO they have an Operating value of 6VDC and switching capability of 240 VAC and having 5 connector's as in the
Picture:
I wanted to know how can i connect it to arduino and as its 6VDC will it be able to work with arduino's 5 VDC or not or i have to provide external power source?
normally u can used a pull up circuit. U can use a transistor acting as a switch to be trigger once the output of the arduino goes high. Some uses tri-state buffer or schmitt trigger but must make sure it can pull up the voltage up to 6 volts otherwise it will not be able to trigger the rel.ay
