Connect two uC's trought GPRS (without PPP stack)?!?
mrcube_ns
Advanced Member level 1
Europe
I need to connect 2 uC's and both are connected via RS232 to an Enfora Spider modem. The uC's don't have any PPP stack. I just need to send plain ASCII information from on uC to another. I have already done it with SMS, but we would like to change to GPRS.
I have SIM cards with fixed IP addresses.
Someone told me that Enfora has PPP to serial converter, if does how to activate them.
Can anybody help?
Mr.Cube
I already done that GPRS connect SERVER.
Because the GPRS is not fixed Ip,2 GPRS connect have problem.
JOHN
Jonh you dont read carefully what I'm wrote.
Any ideas?!?
Mr.Cube
    V
Any ideas?!?
Mr.Cube
Even with fixed IP address you may not be able to route the packets if the provider has not configured internetworking routes. Are they public ip address or onky valid inside the provider network ??
I can do ping when I connect on 2 PC from windows (I ask and provider let me to do that). Basicly provider do all routing inside.
Mr.Cube
    V
hi .. with AT+CGDCONT you Define PDP Context .. afaik most supported pdp type is IP. however some modern gprs modems can do ppp stack for you so you just connect on tcp level and can send data through
Thanks to all posts.
I made it, its work.
Enfora has PPP to serial converter in inself, so your devices dont need to have PPP stack inplemented, Enfora do everything. Trick is to activate this converter.
For further information try on:
www.enfora.com
Mr.Cube
Hi All,
It is odd that you need the PPP operation by all means, unless you are using the mobile module to dial-up to an ISP.
Normally, my experience is that, after activate the GPRS, you just need to send up one side as server (listen to a local port), and the other side as a client (connect to the remote port).
This is similar to two computers connected to same network, the only way to connect to each other with ethernet is a server-client communication.
Any comment ?
Any comment ?
YES, but MC35 cant work on that way. It's simple GSM/GPRS modem without any advanced features.
I resolve problem by replacing MC35 with enfora modem which has that features.
Thanks.
Mr.Cube
Mr.Cube,
Pls tell me from where you get Static IP SIM cards?
