connect reset pin to i/o pin
ahmadabad
I will reset microcontroller AVR via software.can I connect reset pin to output pin (i/o pin) in Atmega 32 or 128 and pull down this output for reset of microcontrolller?
HI
You can do that - but keep the I/O pin as input when it is not in use (not applying reset)
All the best
Bobi
The microcontroller specialist
Why do not you simply branch to the starting address of your code?!!
Amr
there are many simpler ways to reset a mcu than to take up potentially two IO pins.
the following links will help you
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=83625
P.Ashok Kumar
I want a function that any time call it function ,mcu go to reset
Added after 30 seconds:
Added after 47 seconds:
rather than yelling back, you probably should learn to read others' responses as they clearly point to multiple solutions to your problem.
Or you remain un-helpable.
