rajudp
Advanced Member level 2
can we connect 4 tubes 18w to a single electronic ballast by adding 3 more inductors parts. i searched the web but most of them using maximum 2 tubes
As we all know in India we still use conventional chokes and ignitors to illuminate 400watt HID lamps. Is there any electronic alternative to the same application? Cheerstechnorachit said:You may use 4 tubes of 4W in parallel, but if you want to increase its capacity, you need to wind up a new transformer, and not an inductor. You must also check the Watt- Rating of the Transistor that powers the transformer...if you need more help regarding this.....you may contact me....
Regards Rachit
