tony_lth
Advanced Member level 5
I read this sentence:
LTE has a spurious emissions spec of <-36 dBm/100 kHz in the frequency range of 30 MHz to 1 GHz (refer to Section 6.6.3 in the 3GPP TS 36.101 V 9.5.0).
I want to confirm it's meaning is: Per 100KHz, the spurious emissions power is less than -36dBm, right?
How to measure it? If use spectrum analysis, set RBW=100KHz, so the noise floor should be less than -36dBm, right?
I appreciate your reply. Thanks.
