[SOLVED] Configurable Mircrocontroller design
qbone
Member level 3
Member level 3
Lyngby, Denmark
Hey Guys.
I am looking for a little help in the theory of creating a specific project.
What do I need in order to make a controller with a MCU where I wanna be able to write programs on my PC and easily download them to the controller?
Like if the controller have 12 I/Os I want one program where the 12 I/Os do one thing, and one program where they do another thing.
These program I want in seperate files, and being able to download them through either a self made application or one that already exists..
Kinda like downloading a new firmware to the controller I guess.
How complex a MCU do I need for this, and how or where do I need to store the program? External RAM or ROM?
I don't need complete schematics or whatnot, all I am asking for is for a little guidance as to What components would I need, and what theory would I need to acquire so I can move onwards with this project?
I am an electronics technician apprentice, so I am not a complete noob when it comes to electronics, but so far I have mostly been working with analog designs, so my designer skills in digital design arent as badass as I want them to be some day ;)
I hope you can help me out.
After doing some reading I would assume that I would have to write the program onto an eprom, otherwise it would ofc be lost during reset, but wouldn't I need another Rom aswell, or one embedded in the MCU, where I write all my routines as to how it should download programs and behave on startup and all?
Sounds like what you are looking for is a serial "bootloader". A program that you write into the MCU once and then protect from being overwritten, that allows you to load other programs into it for execution. There are many MCUs that can do this, look for ones with "self write capability" and "flash memory" to get examples.
Brian.
Reactions: qbone
    qbone
Most micro-controller use FLASH memory for their program memory and are not capable of running programs out of RAM. To update the program memory you use a "Boot Loader"; a small piece of code that downloads your program and copies it into the FLASH program memory space. The Boot Loader is typically located in a protected section of program memory so it can not be overwritten. Depending on your micro-controller,and peripherals, your program can be downloaded from a serial port, Wi-Fi connection, Ethernet, USB, or from an SD card - among other ways.
Microchip has several application notes and sample code for boot loaders for their products:
Reactions: qbone
    qbone
