rpm4159
Hello,
Is there a way to change the via depth through scripts based on what layers are seen in the same vicinity when importing a GDS into HFSS. Basically trying to streamline the layout to HFSS sim process and one of the challenges is controlling the via depth when certain capacitor layers are present. For example, if Capacitor layer 1 is present where Via is present under Metal 1 , then via depth stops at capacitor 1 layer. Otherwise (if Capacitor layer is not present) via depth continues from Metal 1 to Metal 2. Im trying to avoid having to manually change the via depths to prevent short circuits and avoid extra steps if possible.
Thank you.
Thank you.
