Can below conditional operator be used inside sequential always block?
c ? a: b;
Can case statements be used inside sequential always blocks?
yes, you will lose your job for complete inability to write logic like a human. fired for cause on the spot.Will there be cons if a flipflop is coded as rtl in the following way instead of using traditional if-else inside the same always block ?
always @(posedge clock or negedge rst)
(!rst) ? (q<=0): (q<=d);
Let's wait on what FvM and dave_59 says on this.yes, you will lose your job for complete inability to write logic like a human. fired for cause on the spot.
in a more serious tone, this style goes against typical coding styles. synthesis tools might complain or might even misinterpret the intent (unlikely). in short, there is no good reason why anyone would ever write this freakshow of a code.
q<= !rst ? 0 : d;
even if it was somehow LRM-compliant, it doesn't mean much. synthesizable RTL is a subset of the Verilog language. not everything that simulates becomes (useful) hardware.Why will not the below code work? What Verilog LRM violation is there that the below code will not synthesize to a D-Flipflop?
Sorry, it was missed. You are right.It's a conditional expression without an assignment (no LHS). Not valid statement.
