Concerns about noise from LDO regulator for PLLs
emax0198
Member level 2
Member level 2
20uv ldo
I am going to use MAX883 low drop out voltage regulator for a PLL design using MC145170. I am concerned about the noise that this regulator is going to introduce in the circuit. The data sheet shows output noise voltage to be 250 micro Volt RMS.
Is it fine to use this regulator for this PLL?
