Concept HDL and Allegro Frequent errors and solution
binu G
Advanced Member level 2
Bangalore
allegro concept hdl
hi
how can i cross probe between concept HDL and Allegro?
Is this possible like the way in capture and layout?
else, Is there any third party tool which do the same?
library not defined cadence
What exactly you mean by cross probe?
If you mean highlighting signals in both the tools together, then it is possible. If both tools are invoked under the Cadence Project Manager and if you click on one connection in ConceptHDL it gets highlighted in Allegro.
- Neeraj
    binu G
ptf file allegro
no iam not able to do the same.
what could be the problem .
is there any envn setting required for the same ?
binu g
how to create part table in concept hdl
It worked
with "Design Reference" tool builtin with the concept HDL.
Binu G
allegro .psm file
how to fix this error ?
Library not defined: -lib "bin_lib" -cell "dummy_root_design" -view "cfg_verilog" -file "expand.cfg"
Binu G
concept-hdl allegro
What is the role of the *.Ptf file?
how i can create the ptf file for the present library which is released by the Cadence?
Binu George
cadence allegro create ptf file
Binu George
open pcb librarian expert, next open cell from library, after that Tools > part table editor > file > new part (of file)
Serg
Serg
Cadence PSD come with library, but iam not able to find a *.ptf
is there any methord to generate the same?
i mean an automatic process.
Please correct me if my question is wrong.
Regards
Binu G
$location allegro hdl
Binu George said:
Serg
Regards
Binu G
No automatic process, *.ptf you can to write only manually in part table editor, because it consist of information about component.
For example, you have resistor, which consist of sym and footprint (several footprint's), but exist other information about resistor nominal, tolerance, producer .......... It's information keep in *.ptf. You have to attach *.ptf to your design and take necessary resistor from *.ptf.
Serg.
cadence ptf part table
hi,
how i can create the library from the current layout in allegro?
Is this possible like in the PADS?
binu g
Solution found for creating the library from the *.brd.
"dlib" is the command used in the console
which help to develope the psm and dra files.
