computing roots on a calculator
Zak28
Advanced Member level 2
currently calculators accept square roots as sqrt(9) which is 3
but how to change the root so as to compute a cube root or more than 3rd roots?
A basic method to take cube root of 9:
* take log(9)
* divide by 3
* take antilog
A scientific calculator has a button to calculate X to the Y power. The cube root of 9= (9)^1/3 power.
Or a button to calculate #Xth root of Y.
Reactions: Zak28
    Zak28
* take log(9)
* divide by 3
* take antilog
I meant on calculators such as bc or the google chrome searchbar calculator.
It cannot be done (in a single step) on a basic calculator; but the search bar calculator is quite powerful.
You can type either ** or a ^ as the power symbol (operation). In other words, x**y and x^y means the same: x raised to the power of y.
If the power is integer you simply type it as such. For roots (say cube roots) you need to type 1/3 in parenthesis: 27^(1/3) will give you 3.
Internally, the numeric processor uses an algorithm very similar to the one pointed out in post #2. If both x and y are floats, x^y is computationally very expensive in time (it does take lots of time or cpu cycles).
Reactions: Zak28
    Zak28
They should implement
crt(x) cube root
qrt(x) quad root
currently only sqrt(x) is implemented.
The nth root of a number x can be found by x^(1/n). If you have the x-power-time button, then you use it.
crt(x) cube root
qrt(x) quad root
It has already been implemented. But it's dynamic, so you can select the power you wish yourself. That is what has been done with the x^y function.
Reactions: Zak28
    Zak28
qrt(x) quad root
It is simple if you have the sqrt function: quad root is nothing but sqrt(sqrt(x)).
If you are familiar with Newton Raphson method, you can use that for many different problems.
The real problems are (float)^(float)- they are hard to manage numerically.
Reactions: Zak28
    Zak28
Its not implemented I might file a bug with bc if they have a tracker.
As documented, bc ^ operator supports only integer power arguments. e(l(x)/3) however works. You can define it as a function if you like. Or use a somewhat more elaborated calculator.
Reactions: Zak28
    Zak28
