Computer hangs while working with serial port communication
Suraj Shrestha
Junior Member level 1
serial port converter computer hang
I am working in serial data communicatin with COM1 as the transmitter and COM2 as the receiver configuring the cables with NULL MODEM configuration but while I execute my own program written in C, but it hangs and no symptoms to get the result. Hence, anyone who are eager to help me please send me a simple working program with satisfying my above mention configuration.
Thanks in advance.
Re: Computer hangs while working with serial port communicat
What OS are you using?
Hi
I used to have this problem when there was a faulty ground from the mains. Check the computer supply.
Also verify you are using the correct ports in the program.
