As you are on PLDs forum, it is easy to write a behavioural code for this.
You can use 1 comparator if you want but you'll have to do the comparison 15 times. All data inputs would have to pass through a bus so don't forget the high-Z state.
Simple IF statements in a process should suffice.
First of all, you may create 16 registers of 9 bits, regt0 to regt15, and 2 comparator registers, compA and compB. Then you transfer the data from regt0 to compB and from regt1 to compA and save the data "greater than or equal to" the other data value in a back into compA. Then move the data in regt2 to regt15 to compB one at a time to compare with compA each time saving the "greater or equal" value back into compA. At the end, you'll have the greatest value in compA. You can then subtract each of data in regt0 to regt15 from the content of compA.
You can even keep track of the register with the greater data value in a 4-bit register and update it as you are doing the comparison.
