It is a construction of processed refrigeration unit, parts of which were used to create a compressor.
What also you will need:
- 10l tank
- pressure switch
- regulator with water separator
- wheels (for example from an old mower)
- elements of gas pipe 3/8”
- 30mm angle
- pipe for handle
Wheels are used because the device turned out to be too heavy. You can also add soldered “hanger”.
Safety fuse was made of a 25cm long piece of hose, through which air gets inside the tank from the compressor. It can be seen in one of the pictures. Its resistance should be about 6 atm.
Link to original thread - Kompresor z agregatu chłodni (450W)
