The whole device is 99% from an old compressor.
What is needed:
- a compressor hs 11, used in Ursus C-330
- a big pressure tank from Star
- a little pressure tank from C-330
The whole device is powered by an inductive engine 1,1KW, on a proper move.
There is a possibility of setting on the little tank of about 15L, by closing the big tank, which enables reaching pressure of about 8bars to minor works or setting the both tanks on in a really short time.
In this case, total capacity (with pipes) enlarges into more than 60L. The pressure switch is set to switch off at the pressure about 7bars. This could extend the life of the compressor. It switches on at about 4bars.
Then, a controller output and the cooling (turbine engine from a kitchen hood) were added.
Also, a control board, as seen in the picture, was projected and self-made. It took about 5 days of work.
The compressor still needs painting, placing the cables etc.
Link to original thread – Kompresor ze sprężarki Ursus C-330 konstrukcja własna
