Compiling problem with TCP/IP Stack using ENC28J60
Kounista
Junior Member level 2
Tunisia
Hi everyone,
I'm trying to build my own ENC28J60 based application. I've already programmed PIC18 microcontrollers using MCHP C18 and i never had problems with that. However, it's the first time i'm using the ENC28J60 with a PIC184620.
After reading the whole AN833 document and examining the demo projects found in the TCP/IP Stack folder, i want to start my own specific application. For that the AN833 provides this very basic code:
Since i'm only using UDP and DHCP i included the DHCP and UDP modules in the example above. After modifying the Stacktsk.h file depending on my application requirements (UDP and DHCP) i got this single error when compiling:
"StackTsk.c:182:Error: syntax error" which means i have a problem with line 182 which contains this: ICMP_CODE ICMPCode;
The whole union code in which this identifier can be found is:
union
BYTE MACFrameType;
BYTE IPFrameType;
ICMP_CODE ICMPCode;
} type;
Since the Stack manager doesn't need the ICMP.h file to be included (according to AN833) and that i'm only using UDP and DHCP, i commented this line on the StackTsk.h file:
// #define STACK_USE_ICMP
Can someone with a good knowledge on the subject please tell me where i'm doing it wrong? (or if i'm doing it all wrong?)
- TCP IP Stack version used: 3.02
- compiler: MIcrochip C18
- Hardware: PIC18F4620 and ENC28J60
thanks.
