Compiler doesn't recognize header files from Texas bsl library
shanon_uetian
Junior Member level 1
i am using the texas bsl library but it does not compile
and error by copiler is isseud about the methods used says symbol not recognised
it does not recognise header files i import from library
Re: Texas bsl lib
u will be working with dsk6711 and ccs2.1 now the bsl is obesolete
you should try using csl library and use the help for csl from ti help docs
