Compile Xilinx ISE library for external Modelsim simulator
promach
I have the following errors using compxlibgui to compile Xilinx ISE libraries for external Modelsim simulator.
Any advice ?
RUNNING NEW INTEGRATED COMPXLIB ...
compxlib -s mti_se -64bit -p /opt/altera/modelsim_ase/bin/ -p -l verilog -arch spartan6 -arch spartan6l -lib all -w -exclude_superseded -verbose -dir /home/phung/Downloads/DDR_backup/DDR_Xilinx_ISE/modelsim/
Output from log file : compxlib.log
    ____  ____
  /___/  \  /    VENDOR      : Xilinx Inc.
  \   \   \/     VERSION     : 14.7 (P.20131013)
   \   \         APPLICATION : compxlib
   /   /         CONTENTS    : Compilation Log
  /___/   /\     FILENAME    : compxlib.log
   \___\/\___\
Processing command line ...
Reading the compxlib configuration file - 'compxlib.cfg' ...
ERROR:Compxlib:387 - COMPXLIB[option]: Invalid directory '/opt/altera/modelsim_ase/bin/ -p' specified for -p.
Library Source Paths => '/opt/Xilinx/14.7/ISE_DS/ISE'
Current Working Directory => '/home/phung/Downloads/DDR'
Compilation Mode = FAST
Execute Mode = ON
Scheduling library installation & compilation for architectures: spartan6 spartan6l
Scheduling library installation & compilation for libraries: simprim unisim xilinxcorelib edk
Signature:-
compxlib -s mti_se -64bit -p "/opt/altera/modelsim_ase/bin/ -p" -l verilog -arch spartan6 -arch spartan6l -lib all -w -exclude_superseded -verbose -dir /home/phung/Downloads/DDR_backup/DDR_Xilinx_ISE/modelsim/
Executing cmd '/opt/altera/modelsim_ase/bin/vlog -version' with output '.cxl.mti_se.version' (Tue Dec 21 10:16:23 2021)...
RunWindow on the command '/opt/altera/modelsim_ase/bin/vlog -version'(.cxl.mti_se.version).
COMPXLIB[exe]: The command line '/opt/altera/modelsim_ase/bin/vlog -version' ran to completion with return code 0.
ERROR:Compxlib - COMPXLIB[sim]: Unable to automatically find executables for simulator 'mti_se' from the following paths:
    /opt/Xilinx/14.7/ISE_DS/ISE//bin/lin64
   /opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64
   /opt/Xilinx/14.7/ISE_DS/ISE/sysgen/util
   /opt/Xilinx/14.7/ISE_DS/ISE/sysgen/bin
   /opt/Xilinx/14.7/ISE_DS/ISE/../../../DocNav
   /opt/Xilinx/14.7/ISE_DS/PlanAhead/bin
   /opt/Xilinx/14.7/ISE_DS/EDK/bin/lin64
   /opt/Xilinx/14.7/ISE_DS/EDK/gnu/microblaze/lin/bin
   /opt/Xilinx/14.7/ISE_DS/EDK/gnu/powerpc-eabi/lin/bin
   /opt/Xilinx/14.7/ISE_DS/EDK/gnu/arm/lin/bin
   /opt/Xilinx/14.7/ISE_DS/EDK/gnu/microblaze/linux_toolchain/lin64_be/bin
   /opt/Xilinx/14.7/ISE_DS/EDK/gnu/microblaze/linux_toolchain/lin64_le/bin
   /opt/Xilinx/14.7/ISE_DS/common/bin/lin64
   /home/phung/miniconda3/condabin
   /usr/local/bin
   /usr/bin
   /var/lib/snapd/snap/bin
   /usr/local/sbin
   /opt/cuda/bin
   /opt/cuda/nsight_compute
   /opt/cuda/nsight_systems/bin
   /var/lib/flatpak/exports/bin
   /usr/lib/jvm/default/bin
   /usr/bin/site_perl
   /usr/bin/vendor_perl
   /usr/bin/core_perl
   /opt/altera/quartus/bin
   /opt/sonnetsuite/bin
   //home/phung/.local/bin
   /opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64/.
Simulator 'mti_se' is ignored.
It says right there:
[phung@archlinux DDR]$ ls -al /opt/altera/modelsim_ase/bin/mti_se
lrwxrwxrwx 1 root root 33 Dec 21 10:16 /opt/altera/modelsim_ase/bin/mti_se -> /opt/altera/modelsim_ase/bin/vsim
You are also trying to compile xilinx libraries in what I believe to be the free altera edition of modelsim. I'm not sure this is possible.
Only Intel (Altera) offers free Modelsim (starter edition) software now.
@promach, No.......the Microchip Libero SoC tool comes with a ModelSim that can be used with Xilinx toolchains.
My colleague is successfully using this Modelsim provided by Microchip for a Vivado based project.
You also need to apply and get the free node-locked license from Microchip for Modelsim to work.
I think he used this AR https://support.xilinx.com/s/article/64083?language=en_US and common-sense!
An advice - you must be very careful about all the path settings (loc of the simu executable, loc of precompiled libraries, etc)!
compile_simlib is for Vivado, but I am now looking for solution with regards to ISE.
