frankqt
Member level 4
I have a system where I sample some data periodically (every 10usec). The shape of the data is triangle, in other words it linearly increases and decreases in time. (Both theory and practice are in agreement, I plot the ADC output and I clearly see linear increase and decrease although there is some non-linearity but let's ignore that for the sake of discussion) However the frequency of the signal is not fixed. It may increase very fast or very slow. (narrow or wide triangle)
I am trying to locate the true peak point of the data with 500nsec accuracy, however my ADC samples every 10usec. One item on my favor is that the data values increase and decrease in sequence. I get worst case 50 samples, best case 1000 samples. (in worst case, I will have 25 samples in increasing order and 25 in decreasing order)
How can I approach this issue using DSP techniques? One idea I had was take the derivative of the final sample set and find out the side angles (rising and falling) and calculate peak point from those angles. (I basically extend the left and right side of the triangle and look at where those lines cross each other). I cannot think of any other way. I welcome suggestions.
Thx
Thx
