vangde
Newbie level 3
Hello
I need to connect an electronic scale (designed to weight vehicles) to a PCB with microcontroller that im making.
The scale unit has a DB9 output (serial port) that is labeled RS485.
Thing is that i tried a usb to RS232 cable-converter and it worked fine plus i ordered a module for RS232 to TLL to integrate to the PCB.
I red that RS485 works with differential voltages and can tolerate lower voltages than RS232.
My question is: Is the label RS485 wrong(since it worked as RS232) or the two standards are compatible?
Is it safe to connect my usb cable-converter or the RS232 to TLL module for long periods of time and not endanger the scale unit?
