Comparing Data in text file with Simulation Result?
mariamtr
Newbie level 1
Newbie level 1
I am using DVE .
I need to do a black box verification which consists of running my design and then compare whether the data from my waveform are the same with the data provided by the designer.
the problem is that the data provided by the designer is in a text file and it is very long : To compare the data using my own eyes would take ages and will probably make me a squint.
So I was wondering if there is a tool in DVE that enable me to do an automatic comparison
PS: I am verifying the memory contents not output of my design
Not with reference to DVE ,if you can save the verification data
in text format then you can compare.
