comparator with internal hysteresis
The negative threshold would decide , when the POR triggers again if VDD starts to fall.
You could look into maxim site, one of theri application notes talk on it.
For example:
If VDD goes below VDD-10% POR should trigger again and generate the reset . this reset stays applied till VDD does not cross the positive threshold. Once the positive threshold is crossed, the reset still remains applied for certain duration say 150ms and then is removed. All is subject to condition that VDD does not go low again
Added after 7 minutes:
You can go through the following application note from MAxim.
