[SOLVED] Comparator gives wrong Output
padfoot_1729
Newbie level 1
Newbie level 1
Hi guys,
I had been practicing a few problems in verilog and got stuck on this :
Question : write a program so that output should be 1 when 'x' is greater than or equal to 'y'
x and y are binary
My logic module:
Code Verilog - [expand]
module comparator(
input x,
input y,
output z);
assign z = ~y + x ;
endmodule
My stimulus/ test-bench module :
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
`timescale 1ns / 1ps
module stimulus;
reg x;
reg y;
wire z;
comparator uut (
    .x(x),
    .y(y),
    .z(z)
initial
begin
x=0;
y=0;
#20 x=1;
#20 y=1;
#20 x=0;
#40;
end
initial
begin
$monitor("x=%d, y=%d, z=%d \n",x,y,z);
end
endmodule
OUTPUT OBTAINED:
Please Help with the above issue, output is shown as 0 when x=1 and y=0.
Thank you!!
Since the question wants you to compare values for greater than the inputs x and y should not be single bits but should instead be a vector, so they can be more than just 1'b1 and 1'b0.
If they are supposed to be 1-bit then the assignment z = ~y + x is wrong since adding won't tell you if x >= y
It should be simply z = ~(~x & y); // result is 0 only if x < y, otherwise if x==y or x>y it is 1
