FreshmanNewbie
Advanced Member level 1
I would like to know whether my below design is feasible.
I have a UART interface in one PCB - Board 1.
I have another PCB board that needs to be connected to a TFT touch display - Board 2. Planning to use this.
Board 3 - Need to develop a board that will give power to the 7-inch TFT.
My question is, can I use board to board connector, to connect the UART interface between board 1 and board 2? Or should I use wires/cables between them?
- Just want to know whether my above design would be feasible. Or do I need to check for any precautions for the digital interface, That is UART? In the case of cables/wires any distance limitation?
- LCD and TFT technology are compatible? I am confused on how the data transmission will happen between board 2 and board 3. When I looked in the TFT datasheet, it is mentioned that the host processor interface that will be supported is I2C. So, the board 2, will be host. Any idea on how it will happen?
