fhongjin
Newbie level 5
- Joined
- Jul 20, 2023
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 76
Hi all,
I am trying to do a common mode stability analysis for a fully differential operational amplifier in Cadence. The opamp is used to build an integrator.I set up my testbench as follow:
However,the stb analysis result I got is like this:
I checked the dc operation point of my transistors and they look fine. The output common mode voltage matches the reference voltage as well.
I also tried to directly short the cap I placed across the opamp. The result of stb is also weird. Could someone lecture me a lil bit on how to correctly perform a common mode stb analysis please?
Thanks in advance for your help!!
