Common Collector question
AMSA84
Advanced Member level 2
Iberian Peninsula
Hi guys,
Can someone explain how in the Rout expression for the common collector transistor the Rs comes divided by (1+β)? I tried to solve by definition, using the Vx at the output node and I got an expression which size was similar to a train :lol:
After you do the math, my rule of thumb is
Unity voltage gain
As input impedance is raise by ~hFE *Re
and output impedance is lowered by ~hFE,
AC coupled load current can never exceed the DC emitter current and starve the junction of current drain. i.e. AC coupled load R must be any higher value than Re.
Andre, thank you for the reference. However they use the T-Model instead of the Pi-Model. I was looking to solve the problem using the Pi-Model. Do you have any idea on how to do this?
Regards.
