ZaeemAhmad
Junior Member level 2
I want to design an multistage audio amplifier with discrete transistors and have already design the first two common emitter stages, the last one is to be a common collector stage. But when I connect an 8 ohm speaker the voltage gain drops considerably. Is it a problem? Also tell me how to design the common collector stage for this 8 ohm speaker (2W). What peak to peak value of voltage do I need?
Thanks!
Thanks!
