Common Centroid & Interdigitization
vbhupendra
Full Member level 4
Full Member level 4
GOA, INDIA
common centroid
what is the difference b/w Interdigitization & Common Centroid layout ?
when to use Interdigitized and when Common Centroid.
common centroid layout
hi we can match the transistors in two methods.
1.interdigitised
2.common centroid.
in interdigitised pattern all the transistors are in interleaved pattern like suppose there are two transistors with 2 fingers each.then
AB|BA
here the first half is exactly mirrored.here the variations for A and B are same.
in common centroid pattern we care for X and Y variations unlike in interdigitised we care only X variations.then
A|B
B|A
common centroid is more precision than interdigitised .ALL differential pairs are matched using this.
current mirrors are matched using interdigitised pattern since they need minimal matching of vgs.
common centroid layout technique
Check this book: "The Art of Analog Layout" by Alan Hastings
common centroid matching
"A disadvantage of common-centroid layout is apparent.That is the need to cross-connect the devices increases the separation between matched devices and may worsen matching in cases where linear process gradients are not the main limitation."
common centroid differential pair
is this disadvantage really? I think most of input device of differentia ampifer use this kind of method,common centroid, right?
In the case of matching vs area, the winner is definitely matching. so, when going for common centroid method , area is of least inportance. if the transistors are not matched correctly then that would really screw up the whole circuit. so common centroid is really a boon . its not possible to always go for common centroid but when ever possible the best thing is to go for it.
common centroid
I think the question should be "common centroid vs symmetry". Both use Interdigitization. By defination, symmetry is always common centroid, but common centroid can be non-symmetry.
Symmetry layout is good, but you should know what you are "balancing", and not just bindly applied it. In the book I wrote "CMOS Transistor Layout Kungfu" I describe some principles on this topics. However, this chapter is not include in the free release in my website www.eda-utilities.com ...
Regards,
Eng Han
interdigitization
U may assume that interdigitization is a special case of a common centroid but with only one row
In transistor matching if the total length of the mirror exceeds 80um or 100um, try to use common centroid for better matching
interdigitate or common centroid
common centroid layout provides better matching as in this method gradients are canceled in both X and Y direction.
Interdigitized method provides gradient cancellation in one direction only.
Ok
common centroid current mirror
I like this topic about interdigi' vs common centroid. One of my concerns, which none mentioned in the previous posts, is that: when the input differential signal frequency is pretty high (like in RF or high speed IO/CML), the interdigi' structure will cause cross-coupling between gate figners. Obviously, common centriod is sortof free of this problem. The structure can be redrawn as below:
interdigi': ABAB
commoncentriod: A B
commoncentriod: B A
I am not much certain of my concern so I'm all ears to any comments on that.
interdigitated and common centroid layout
I think common centroid can be used with following conditions:
1. area is not a concern
2. transistor is not big
interdigitising
Hi, upstairs
Don't you think the two conditions you listed are kinda in conflict w/ each other?
BTW, how do you think about that in terms of high frequency?
common-centroid current mirror
the former is prefered
current mirror common centroid layout
hi ,
when we go for interditization and common centroid. how it will work
linear gradient in centroid
I usually do common centroid on match transistors used in differential amplifier and current mirrors.
While interdigitation on resistors.
interdigitising in layout
inter digitization is inter mixing of required matching units, if we use this we can not match in all directions.In common centroid, the center for two require pairs should be same. so it match the two pairs in all directions.
for e.g if we want match two txrs with 2 fingers.
by using inter digitization: ABAB here the center for both pairs is different the temp& linear oxide gradients will differ.
by using comon centroid: ABAB or
AB
BA
in this method center for both pair is same, so all temp and linear oxide gradients will same for both.
coming usage(Generally):
1. for biasing, current mirrors and resistors we will use inter digitization
2. For input diff pair and cap-array we will use common centroid
resistor common centroid layout
If drain or source is shared in common centroid, the layout could be very compact as well. For current mirror with common centroid, gate connection can be very easy.
common-centroid
Guys,
For high speed (GHz) differential amplifier, should I use common centroid or interdigitized? Both seems to add additional parasitics to the high speed line. What's your experience in this?
Regards.
layout common centroid current mirror
In my opinion the common centroid is the best choice in terms of matching, but of course in High Frequency is all more difficult.
You have to choice the best compromise between matching-simmetry-parassitics.
Good luck
common centroids
I use common centroid for critical layout, use interdigitization for 2nd critical one.
Give layout guys some vacation when I've got loose spec.
