MD_SHAHRUKH
- Joined
- Jun 5, 2017
- Messages
- 103
- Helped
- 4
- Reputation
- 8
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Bangalore, India
- Activity points
- 2,388
Hello community. I hope you all are doing well.
My query is, I have completed the prototype of a system which takes ECG and PCG and display it to a 7inch display unit using Raspberry pi. The front end development was done using python programming, back end using MongoDB (SQL). The key thing I want to change is I want to reduce the size of the whole system, which means, I want to make a customized PCB where the display, main microcontroller, signal conditioning, power supply unit all connected in a single board.
1. How to choose alternative of raspberry pi? Key things need to view in order to search for new controller.
2. What if the operating system changes? Does todays GPOS have python capability to use the existing software.
3. What is the procedure to make sure the software dependency on hardware will not be compromised.
Please reply if insufficient information provided.
