Tractor Beam
This is my first post here so I hope everything is ok. - I read the rules.
Do rf sign waves have a small attraction for each other when they are near the same frequency? I thought that electronics men might know why this happens. My experiment shows that they have some attraction for another when two frequencies are very close.
I’m doing a physics experiment with heterodyning of two slightly different frequency sign waves. I set one frequency generator at 1,000,000 Hz. and the other at 999,100 Hz. The two outputs are connected together. The scope shows there is one convoluted heterodyned wave. Then when the lower frequency is slowly moved up near the higher the scope reveals the waves snap together like magnets (so to speak) and have combine into one sign wave as seen on the oscilloscope. Checking the frequency of both I find they are still not quite equal. The attraction seems to hold a nicely formed single sign wave until the frequencies are separated by 7729 Hz approx where they suddenly snap back apart. A very apparent snapping together or locking of the two waves into a single nice sign wave occurs well before the two generators become equal frequencies.
Two separate toggle switches are required at each generators output so to connect/disconnect the generators separately during the experiment. In addition an audio amp w/speaker picks up the heterodyned low frequency (this is an option). The audio amp simply provides an audio version of the output and I can hear the wow as the frequencies get closer. The toggle switches allow the same frequency counter to be used for both generators.
I've tried re-arranging the componets and removing counters and the audio amp but the results are the same. Both generators are set at 5v output.
EXPERIMENT: ATTRACTION BETWEEN TWO RF WAVES OUTPUT FROM TWO FREQUENCY GENERATORS
RESULTS: Locks into a single clean sign wave well before the generators are equal frequencies.
Base Generator Frequency reading 1,000,109 Hz. Only Generator #2 is slowly adjusted until the lock and unlock occurs. At the moment of lock and unlock generator #1 is toggled off to check #2 frequency.
GEN #1
BASE FREQ Constant
1,000,109 Hz
Experiment Step 1
GEN #2
Low to Higher Freq movement
Locks into Single Wave At:
992,967 Hz Diff: 7142
Step 2 After they have locked together.
GEN #2
High to Low Freq movement
Waves Break Apart Separating At:
992,380 Hz Diff: 7729
Why does this happen I don't recall reading anything on this in my studies?
GEN #1
BASE FREQ Constant
1,000,109 Hz
Experiment Step 1
GEN #2
GEN #2
