Combining adaptive and linear in momentum
HaoLi
Hi there,
I have an confusion about using adaptive and linear simulation at the same time.
Usually I use adaptive only, but now I need simulation at certain point. The guide said that I can add linear (or any other) simulation after adaptive simulation, and I did so.
However, in the simulation window, the simulator shows "Adaptive frequency sweep started" then the simulation points are those I set in the linear simulation. Those points used to be in adaptive are not simulated anymore.
Could I trust the result now? Could anyone tell me what is going on in the simulator?
Thank you!!!
Best
Hao
