SvenB
Junior Member level 1
- Joined
- Nov 28, 2014
- Messages
- 15
- Helped
- 4
- Reputation
- 8
- Reaction score
- 3
- Trophy points
- 3
- Location
- Delft, The Netherlands
- Activity points
- 137
Dear all,
I am new to this forum so I hope what I do is correcty, otherwise excuse me.
The problem is as follows: In CST I did a parametric run of the slot-width of a simple lossy slotline calculating the s-parameter balance for each slot width. For each of this width, the balance is displayed from 25 GHz to 35 GHz as is seen in this picture.
The problem is as follows: I want to make a new plot displaying the balance versus slot width at a frequency of 30 GHz. So of each parametric run, only one value needs to be extracted at 30 GHz. I can not find a way to do this in CST. Does anyone know a solution or workaround for this problem without having to export all the files to MATLAB and interpolate all the parametric runs individually at 30 GHz? Because that is very time-consuming and I need to do make this kind of plot very often.
Thank you in advance!
Sven
Sven
