COMBINATIONAL LOGIC PROJECT
asolondon
Junior Member level 2
combinational logic problems
A railway station is designed to control and record the movement of
low, medium and high trucks. A bank of light is on one side of the railway
track while another bank of three photocells is on the other(opposite)
side.
Using logic gates construct a circuit which will light a lamp only when
a medium truck passes, but will be unaffected by low and high trucks.
(This logical ‘1’ output can be used to drive a counter).This logic
gates may include:
Flip flop
NOT gate
NOR gate
NOT-Exclusive
OR gate
AND gate
combinational logic circuits projects
A nice assignment :)
Now you have described it ..
How would you solve it ???
/Bingo
combinational logic design projects
Come on guys! This is elementary logic stuff
combinational logic gate projects
can i get the details of the elementary logic stuff?
electronics logic project
go there:
combinational logic circuit projects
Hi asolondon
Your problem is verry similar to the mouse position detection (inside the mouse is a light source and 2 plastic disks wich obturate the light when you move the mouse ball in x, y directions- the problem is to find the x,y coordonates).
Or similar with the phase comparator problem (used in PLL's)...
Or similar whith the problem of synthessys of RS bistable using 2 NAND gates...
All those problems (and much more!!) had the solutions in asincron state machine theory!!!
combinational logic circuit design+projects
The way I see the problem is a small truck will obstruct only the lower phototransistor, a medium truck will obstruct the lower two phototransistors and a large truck will obstruct all three.
In the schematic, I assumed that an unobstructed phototransistor will produce a HI.
So, three conditions have to be met simultanously for a HI output:
Lower two phototransistors output a LO and the upper one outputs a HI. Since these conditons have to be all true, you just need an AND and invert the signals from the lower two photodetectors. Any other combination is invalid.
