gres
Full Member level 4
It's a column speaker based on low tones (woofer) speaker with longer transmission range ( according to producer 3,2 kHz) and " tweeter" Alphard TE -515 ( that is nothing superb, but enough for bassist.
Dimensions 70x50x34 cm
Capacity about 119 [L]
RMS Power 500W
MAX Power 1000W
Transmission range : without branch point 42~3200Hz or 42~20000Hz.
Casing: OSB plate 18mm
Painting : black spray paint
Additionally :
- double side disconnection " tweeter"
- 4 bass - reflex holes ( resonance) diameter 10cm , 18 long.
I couldn't find holes on long, so just glue PCV and tape what you can see at the pictures.
Casing sealed by silicone ( great sealed and tight )
Column play perfect with 350W amplifier if you want to play on bass guitar, but you can also just listen to the music.
Original text from : https://www.elektroda.pl/rtvforum/topic1464645.html
