PrescottDan
Banned
There is some switches that have a coil , the coil needs to be energized and enabled with voltage in order for the switch to work
The switch is either a Single pole double throw or a double pole double throw
What kind of switch is this called?
It's not a relay
The switch has a lever to move manually , but it will only work even the coil inside the switch has voltage and is energized
It's not a relay
