Code in mikroc to Detect Obstacle using IR(Infrared) Sensor with pic16f877a
Zamzam Faya
Newbie level 6
Newbie level 6
Sana'a , Yemen
i need a Code in c language that im using mikroc for pic to Detect Obstacle using IR(Infrared-sharp) Sensor , and im using for that pic16f877a
this is one part of the project
which IR (infrred material )are u using?
Use PIC as a transmitter of High frequency signal which must be received by a monostable TLC555 which is activate by a zero(0) on pin2.
Web gives you more on monostable circuit,and then apply a buzzer on pin3 of the Triple five through a transistor;The circuit will be working well.
Hope this help!!
