[PIC] Code for dspic33fj32mc204
Umamaheswar
Hello everyone,
I want dspic33fj32mc204 microcontroller sample code with deadtime complementary PWM. if you have please send it.
hello umameheswar sorry for that i don't have that code and iam also trying to that code. my suggestion is ask to khatua sir he will provide that code.
A forum is not meant that others do your job or post code for you.
Btw: an internet search gives a lot of application notes, tutorials, documents that show how to do it.
Even the most reliable ones: directly from the chip manufacturer
So
* copy code or try to write your own according the available informations
* test your code
* try to rectify your code
If you fail to get it running: Show what you have done so far:
* post our code
* post your expectations and test conditions
* post your calculations
... then there will be a lot of people here to help you to rectify your code.
Klaus
I searched in internet i didn't get the code that's i post.
Don't try to be too specific for the MCU in question - the PWM module is probably common across a number of DSPIC32FJ family of devices (and possibly more).
Also look at the Microchip web site for this device and look at the 'Family Reference Manual' (FRM) section for the module. They typically have more detailed examples about how to use the module (but just be aware that some specific devices might not have all of the capabilities mentioned in the FRM - refer back to the datasheet for specifics to be sure). If nothing else it should give you the general direction to get started.
Susan
