kavitha_bonthu
Junior Member level 3
- Joined
- Jan 26, 2008
- Messages
- 31
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,487
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 library IEEE; use IEEE.Std_Logic_1164.all; use IEEE.Std_Logic_arith.all; use IEEE.Std_Logic_unsigned.all; Entity Division Is port( Clock : in std_logic; Reset : in std_logic; Load : in std_logic; Numerateur : in std_logic_vector(31 downto 0); Denominateur : in std_logic_vector(31 downto 0); Ready : out std_logic; Quotient : out std_logic_vector(31 downto 0); Reste : out std_logic_vector(31 downto 0) ); end; architecture Division_RTL of Division is constant ALL_ZERO : std_Logic_vector(31 downto 0) := "00000000000000000000000000000000"; signal ni : std_logic_vector(63 downto 0); signal sub : std_logic_vector(63 downto 0); signal n : std_logic_vector(63 downto 0); signal i : std_logic_vector(63 downto 0); signal d : std_logic_vector(63 downto 0); signal d_int : std_logic_vector(31 downto 0); signal counter : std_logic_vector(5 downto 0); -- attribute syn_keep : boolean; -- attribute syn_keep of d_int, N : signal is true; signal ReadTempo : Std_Logic; begin Ready <= ReadTempo; NI(63 downto 0) <= ALL_ZERO & Numerateur; D(30 downto 0) <= "0000000000000000000000000000000"; D(62 downto 31) <= d_int; D(63) <= '0'; Quotient <=n(31 downto 0); Reste <=n(63 downto 32); Process(Reset, ReadTempo, n ,d ) Begin If Reset = '1' Then sub <= (Others=>'0'); ElsIf ReadTempo = '0' Then sub<= n - d; Else sub <= (Others=>'0'); End If; End Process; Process(clock, reset, ReadTempo) begin If Reset = '1' Then n(63 downto 0) <= (Others=>'0'); D_Int(31 downto 0) <= (others=>'0'); ElsIf Rising_Edge(Clock) Then If load='1' Then n(63 downto 0) <= NI(63 downto 0); D_int(31 downto 0) <= Denominateur(31 downto 0); Else If ReadTempo ='0' Then n(63 downto 0) <= I(63 downto 0); End If; End If; End If; End Process; Process(Reset, Sub, n, ReadTempo) Begin If Reset = '1' Then I <= (others=>'0'); ElsIf ReadTempo ='0' Then If Sub(47)='1' Then I(0) <='0'; I(63 Downto 1) <= N(62 Downto 0); Else I(0) <='1'; I(63 Downto 1) <= Sub(62 Downto 0); End If; Else I <= (others=>'0'); End If; End process; Process(clock,reset) Begin If Reset = '1' Then counter <="111111"; ReadTempo <= '0'; ElsIf Rising_Edge(Clock) Then If Load = '1' Then Counter <= (Others=>'0'); ReadTempo <= '0'; Else If counter="011111" Then counter <="111111"; ReadTempo <= '1'; Elsif counter="011110" Then counter <=counter+'1'; ReadTempo <= '0'; Elsif counter="111111" Then ReadTempo <='1'; Else counter <=counter+'1'; ReadTempo <='0'; End if; End If; End If; End Process; End;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.STD_LOGIC_UNSIGNED.all; use IEEE.STD_LOGIC_ARITH.all; entity division is generic(SIZE: INTEGER := 8); port(reset: in STD_LOGIC; en: in STD_LOGIC; clk: in STD_LOGIC; num: in STD_LOGIC_VECTOR((SIZE - 1) downto 0); den: in STD_LOGIC_VECTOR((SIZE - 1) downto 0); res: out STD_LOGIC_VECTOR((SIZE - 1) downto 0); rm: out STD_LOGIC_VECTOR((SIZE - 1) downto 0) ); end division; architecture behav of division is signal buf: STD_LOGIC_VECTOR((2 * SIZE - 1) downto 0); signal dbuf: STD_LOGIC_VECTOR((SIZE - 1) downto 0); signal sm: INTEGER range 0 to SIZE; alias buf1 is buf((2 * SIZE - 1) downto SIZE); alias buf2 is buf((SIZE - 1) downto 0); begin p_001: process(reset, en, clk) begin if reset = '1' then res <= (others => '0'); rm <= (others => '0'); sm <= 0; elsif rising_edge(clk) then if en = '1' then case sm is when 0 => buf1 <= (others => '0'); buf2 <= num; dbuf <= den; res <= buf2; rm <= buf1; sm <= sm + 1; when others => if buf((2 * SIZE - 2) downto (SIZE - 1)) >= dbuf then buf1 <= '0' & (buf((2 * SIZE - 3) downto (SIZE - 1)) - dbuf((SIZE - 2) downto 0)); buf2 <= buf2((SIZE - 2) downto 0) & '1'; else buf <= buf((2 * SIZE - 2) downto 0) & '0'; end if; if sm /= SIZE then sm <= sm + 1; else sm <= 0; end if; end case; end if; end if; end process; end behav;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following lines to use the declarations that are -- provided for instantiating Xilinx primitive components. --library UNISIM; --use UNISIM.VComponents.all; entity div_binary is Port ( ina : in std_logic_vector (15 downto 0);-- range 0 to 99; inb: in std_logic_vector (15 downto 0);-- range 1 to 9; quot: out std_logic_vector (15 downto 0);-- range 0 to 99; rest : out std_logic_vector (15 downto 0));-- range 0 to 99 ); end div_binary; architecture Behavioral of div_binary is signal a,b: integer range 0 to 65535; begin a <= CONV_INTEGER(ina); b <= CONV_INTEGER(inb); process (a,b) variable temp1,temp2: integer range 0 to 65535; variable y : std_logic_vector (15 downto 0); begin temp1:=a; temp2:=b; for i in 15 downto 0 loop if (temp1>temp2 * 2**i) then y(i):= '1'; temp1:= temp1- temp2 * 2**i; else y(i):= '0'; end if; end loop; rest <= CONV_STD_LOGIC_VECTOR (temp1 ,16); quot<= y; --quot<= conv_integer (y); end process; end Behavioral;
-- Divide clock by 5
library IEEE;
entity clk_div5 is
port ( clk :in std_logic;
clk_out :out std_logic:='0');
end clk_div5;
architecture Structural of clk_div5 is
signal set_clk_out, reset_clk_out: std_logic:='0';
signal counter :std_logic_vector(2 downto 0):="000";
begin
process (clk)
begin
if (clk'event and clk='1') then -- rising edge of clock
if (counter(2)='1') then -- check for counter=4 (100 binary, but we check only bit2)
counter<="000"; -- reset counter value
set_clk_out <= not reset_clk_out; -- set clk_out to 1
else counter<=counter+1;
end if;
end if;
end process;
process (clk)
begin
if (clk'event and clk='0') then -- falling edge of clock
if (counter(1)='1') then -- check for counter=2 (10 binary) and since we are in a falling edge this is actually 2,5
reset_clk_out <= set_clk_out; -- set clk_out to 0
end if;
end if;
end process;
clk_out <= set_clk_out xor reset_clk_out;
end Structural;
