Code for combination module in the sequential circuit
tarkyss
Full Member level 6
Full Member level 6
China
for a combination module in the sequential cirtuit,
verilog code like below is ok? is there any problem?
always @( reset or a or b)
about reset
Hi tarkyss,
Why to use reset signal in your combination module?
If you use the reset as enable signal, you may use another singal to connect this module.
about reset
From the RTL coding points of view, it is OK. But if you mean it is a good design practice or not, it depends to your design and what you want to do with reset in your combinational logic.
Re: about reset
because a counter is needed to count the pulse of a signal,
so i must give a initial value before count.
another questions i am afraid the counter will introdue latch.
but if dont use counter, how to implement the funtion that count the pulse of a signal.
about reset
Here is a basic counter.
module top (clk, reset, count);
  input             clk, reset;
  output reg  [7:0] count;
  always @ (posedge clk or posedge reset) begin
    if (reset)
      count <= 0;
    else
      count <= count + 1;
  end
endmodule
about reset
echo47, if i can implement it with clock, i would not ask for help here
about reset
You question is too unclear. Please give more information.
"always @( reset or a or b)" is a valid way to start a verilog block.
about reset
no clock
t is input
w is output
every the nth( n may be 1 2 4 t becomes high level,
w output a high level, the width is the same with t
always @( reset or t )
if( Reset )
begin
counter = n;
w= 1'b0;
end
else
begin
if( t )
begin
counter = counter + 1;
if( counter == n)
w = 1'b1;
end
else
begin
w=1'b0;
if( counter == T )
counter = n;
end
end
reset is a global asy signal , put it in always list with other normal signal , is there any problem?
if i dont want to introduce latch, how can i code?
thanks
about reset
Without having a latch, how can you keep the counter's value?
I think the latch is the only way and you can use the reset in always block.
about reset
if use reset as above, do it cause reset signal unclear?
about reset
what do u mean by unclear reset? When you are doing an asyc design and using latch, you have to make sure you do not have any glitch or transition when the latch's gate is open, if the reset and other signals are stable, then you can use them that way.
Re: about reset
The "t" input looks like a clock. You seem to be trying to use asynchronous syntax to do a mostly synchronous job. That can give a variety of unexpected problems. It's better to use synchronous logic wherever possible.
I'm not sure I understand the desired behavior, but how about this?
module top (reset, t, n, w);
  input             t, reset;
  input       [3:0] n;      // any value from 1 through 9
  reg         [3:0] counter;
  output            w;      // output one pulse of width t for every t input pulses
  assign w = ~counter[3] & t;
  always @ (negedge t or posedge reset) begin
    if (reset)
      counter <= 0;
    else
      counter <= (counter == 0) ? 1 - n : counter + 1;
  end
endmodule
Here's a ModelSim output with n=4, and then changing to n=2:
Re: about reset
echo47 said:
thank you very much
what problem ? for example? It's better to use synchronous logic wherever possible.
yes
  input             t, reset;
  reg         [3:0] counter;
    if (reset)
      counter <= 0;
    else
  end
endmodule
the above code will generate a flip-flop, and the t is connect to the clk port of flip-flop, is it ok? and would introduce any problem? the whole system is syn, but the block i said is of no clk and is combination logic.
about reset
I think the name "t" is throwing you off track. If you simply rename "t" to "clock", then you will see that this is an ordinary synchronous project, except for the AND gate at the "w" output. (Unless I misunderstood the project requirements.)
If you try to implement a binary counter using asynchronous logic, you must be extremely careful or else the synthesizer will generate hazards and races that cause erratic counting in the target device. A gray counter would help, but still that's a clumsy approach.
Yes, you want the synthesizer to use real flip-flops connected to a low-skew clock distribution net (probably named "t").
    tarkyss
Re: about reset
i am sure t is not clock, the period is not fixed, the time between two high pulse is not fixed
about reset
That's fine. A clock that varies in period is still a clock. Synchronous logic and asynchronous logic don't care what the period is, unless it exceeds the speed of the chip.
Re: about reset
You are right that echo's code synthesizes to a flipflop. But the fact that there are no other input signals that are asynchronous wrt t (with the exception of reset which has been handled), the flipflop performs identically to a latch.
You can of course alternatively code a latch.
  input             t, reset;
  reg         [3:0] counter;
  always @ (t or reset) begin
    if (reset)
      counter <= 0;
    else if (t)
  end
endmodule
Just to note that this code is less efficient for simulation purposes compared to echo's one as the always block is triggered more frequently, ie during falling edge of t and reset.
p.s. please use the code tags for the benefit of others.
about reset
checkmate - that needs to be "else if (~t)" because I originally used negedge.
That works fine in behavioral simulation, but post-route simulation (Xilinx Virtex-II) is a mess, probably due to clock skew problems. I see counter bits oscillating at about 1 GHz. The place-and-route software emitted various warnings, telling me I was attempting to do dumb things.
Do you know if there are ways to make this work? Just an academic question - I would normally never attempt this. ;)
Similar discussion in another thread:
Re: about reset
your code is not so good .
