CODE::BLOCKS IDE CROSS COMPILER USING FREE C AND C++ COMPILE
VSMVDD
Banned
Advanced Member level 2
scotland uk
FIRST
CODE::BLOCKS is a must have ide
www.codeblocks.org
download the rc2 installer and install it
visit the forum
next download the nightly build the mingw dll and also the wxwidgets dll
make a folder within the codeblocks installation called NIGHTLYS
unpak the newest nighly build to the nightly folder
and change your ide startup shortcut to point to the exe file
within the nightly and not the main folders version
unpak the two dlls to the nightly folder
and your ready
there is two flavours of installer
one that comes with mingw and one that hasnt got it
for c compilers like SDCC etc{more get added all the time}
you dont need mingw unless you use c2c or another type micro c style you can also plumb in
youll find it a friendly place to write code and it works magic!!!
for c++ it is also hard to beat
offering multiple compiles accross several compilers and platforms
good luck with code::blocks
at least give it a go
for micro c language and micro chips as well as high level support
its really hard to beat
youll find the guys there very ready to solve any bugs
and ive so far had little problems i did solve
www.codeblocks.org
if you need help to set it up pm me and ill help
also dont forget to add the nighlys as its crap without it
the main rc2 version is very old
oh.... and its free .... there is a plugins sdk {and many plugins already}
and the source for the ide is there also
