code block software giving compiler error
ep.hobbyiest
Full Member level 4
Full Member level 4
I have started to use Code Block software for coding. but it is giving problem that compiler is missing. I tried
1. given available path of compiler
2. Download Microsoft VC++ software and give this path.
I don't know how to get it to work.
Hmmm, try to acess settings>compiler and select GNU GCC Compiler, This one I know is compatible with C and C++, but you can try anothers. Also be sure if you are creating a file SOURCE with C++ language.
Cheers pal :)
Hmmm, let's get to the bases. Try to run the Codeblocks as administrator and unistall it and install another version of the program.
Good luck pal
