cocentric in linux, can't chose linux platform to install
xworld2008
Full Member level 4
Full Member level 4
When i install cocentric (ccs 2002.05)in linux,i find when i can't chose linux platform to install.I read the script of install.now ,i find the script has a
error,when input linux it don't set os to linux.Anyone can give a right
install.now ,thanks!
Re: cocentric install error
Dear my friend,
I think your Linux version is not good. Go to synopsys site and read documents to find recommended linux version (possibly RedHat 7.2).
last time when i install the synopsys syn 2002 5 under redhat 7.2 i met the same question. u can view the file install.now to find the problem.
in my case , i changed the folder name 'linux' to 'LINUX' then it work well,
good luck
btw
where can i find the cocentric to download?
thx
Hi, old problem and probably solved by author, but maybe somebody will be still interested...
I had the same problem with 2003.03 version on RH9. I make one change to install now and installed all. You can find in install script:
    # revisit this if... for HP CDROMs that capitalize everything...
    set name=`uname -a | cut -f 1 -d" "`
    if ( ($plat != "HPUX10") && ($plat != "HP64") && ($plat != "HP32") ) then
      # hpux10, hp32 and hp64 machines will uppercase all platforms. (10/19/99)
      if ( $name != "HP-UX" ) then
        set plat = ( `echo $plat | tr '[A-Z]' '[a-z]'` )
      endif
    endif
I changed one line (comment was added):
        # set plat = ( `echo $plat | tr '[A-Z]' '[a-z]'` )
And then I installed all ... but it doesn't work on RH9 :( On RH7.2 all is OK ... I didn't try. Does anybody run succesfully it on RH9? I know that Synopsys supports only RH7.2 ...
All install files names I have are capital letters only.
Mickey
