coax to waveguide transition-HFSS
rotmanlens
Banned
Full Member level 4
hfss+coax+waveguide+transition
i am tryin to build my horn antenna array.i have two things which arent letting me get ahead .
1.since its an array my gain doesnt seem to be increasing with the increase in the number of horns.(note:its not a corporate fed array,horn are individually fed).
2.waveguide to coax transition.tried different probe sizes and did a optimetric analysis for the position of the probe.finally what i have is at the end of the my S11 is close to 0db.
all this has been done in hfss. if anyone has any input to this i would really appreciate it.
regards
sajid mohammed.
coaxial to waveguide transition
i figured the gain part.does anyone has any input for the coax to waveguide transition and viceversa.
thanks in advance.
sajid mohammed.
coax to waveguide transition ads
anymore papers will be hugely appreciated.
sajid mohammed.
waveguide+transition+hfss
s11 near 0 dB indicates a failure in the coax to waveguide transition. Separate the issue into parts. Work on the transition. Then work on the array elements using a modal wave port. Size the waveguide for your operating frequency. Finally when you have the parts working put them together and now you can work on the array.
coax to waveguide
array elements have been worked already.all i am left with is the transition.which seems to be the toughest part.i learnt that the coax transition will include a monopole at operating frequency.and been working as such
if u guys have any papers that would be recommendable to this problem will be highly appreciated.
sajid mohammed.
